Steveu
Re: No1.Paddles and a anchor of some sort.
Yes, get a VHF and leave it switched on all the time on ch16 so you can learn who else is around, what they are doing, what channel the coastguard is on etc it will also teach you generally how people talk on the VHF so when you need to you'll know what channels to use and what to say.
As for navigating, get paper charts in a plastic wallet, spend some time poring over them to decide where you fancy going. Now mark in some waypoints (I use those little sticky paper dots you get from stationers & write letters on them. Then get a simple cheap GPS and programme in your waypoints, storing them under the same name as on your dots. Now when you're at sea you won't know exactly where you are but you will know the dist & course to several local waypoints so you can get your chart out and work out roughly where you are. When you do, look around you and try to identify all the landmarks you should be able to see from the chart. You'll be amazed at how deceptive things can look from the sea, especially off the West Coast with all its islands and inlets.
