Nico Bosham
Hello all,
Welcome to the latest "long time lurker creates an account to ask a question" thread....
As per title I have a slightly odd charging issue on my boat. It's a Jeanneau Sun 2500, with a Yanmar 1GM diesel - one engine starter and one house battery.
Over the course of last season, the house battery charging was a bit hit and miss, as evidenced by the (permanent/fixed) digital voltmeter that is connected to it. Sometime is would be very obviously charging and sometime it would not. If I say, motored for an hour, it would sort itself out and I was never in bother with power for house things, nav, fridge, stereo etc.
This season seems even worse, and I had thought the battery might be knackered, but my (educated) hunch tells me it a charging not a battery issue....
My investigations thus far are as follows:
There is no obvious sign of loose or problematic or degraded cabling anywhere - the house battery is locate in a bone dry storage area under a forward berth, and looks completely spotless.
Could there be a "box of tricks" somewhere - a diode maybe? between the house battery's connection to the alternator that has gone bang? Something that is bypassed/not required when connected to shorepower or daisy-chained? again no obvious sign of this.
I was kind of hoping the house battery was shot, as that's an easy, if expensive replacement job, but it does seem to perform every bit as well as one could expect when charged.
Thanks in advance for any idea of what might be afoot here.
Discombobulated of Bosham.
- Over the course of a day I might for example switch only the fixed voltmeter on first, and all on its own and the display reads 12.2V for the house battery.
- Switching on GPS, Depth and Speed etc might make it drop straight to 11.5V, fridge makes it drop to 11.2V.
- Over the course of a day out, I am seeing single digit voltages and the GPS, and even more horrifyingly, the fridge, stops working (I think Fridge needs 11V+ and GPS 10V+)
- Engine starter reads 12.4V on mulitmeter without engine running. (There has never been a hint that the engine starter is in trouble...)
- I start the engine and using a multi-meter, the voltage across the engine starter reads 13V at tickover and with a moderate amount of "onions" 13.6V
- House battery voltage does not change, even with engine revs.
- When I connect the boat to shorepower, the house battery meter immediately registers 13.4V, and so does multimeter across house battery
- Last weekend, having proved the alternator is apparently charging the engine starter, I
- connected the engine starter to the house battery with some jump leads and the multimeter AND fixed house voltmeter both immediately read 13.4V, which tells me that the fixed house voltmeter is at least accurate - it and the multimeter have never read even slightly differently when connected to the house battery
