Heads filling with brown water?
steve yates
16 Oct 2014
Benfleet, Essex/Keswick, Cumbria
My mates sailing up skye way unhis twister and asked if I had cone scross This isdue? ….
Here is a new boat problem to try and help solve.
Head's, both seacocks closed no leaks around seacocks but bowel filling with brown water.
In theory water cannot back Syphon due to height of discharge tube.
This has happened twice on this trip…..
Never having had a working heads I have no idea :) so thought I’d ask here.
Anyone recognise this?
Minerva
16 Oct 2019
Top tip for playing with the heads - use a facemask and goggles when working on the pump. They are very effective against unwanted wastewater splashes on your lips / mouth…. 🤢
Once is enough
Fr J Hackett
26 Dec 2001
Saou
Noholdingtank, and its a lavac if the model is relevant . Looks like I’ll be telling him to check his joker valve with gloves and goggles :)
It’s more than likely the problem, tell him about measuring the volume of the pipe and converting that into strokes of the pump to clear the crap out of the pipe after use, it will also stop the head ponging
geem
27 Apr 2006
Caribbean
He isn't pumping enough. Residue in the vertical section of the discharge pipe above the pump is bleeding back. If you want perfect clean water, pump 20 times after a no2. Lift lid. Clean bowl and pump another 20 times. Guaranteed clean water in bowl and clean pipes.
srm
16 May 2004
Azores, Terceira.
Lavac does not have a joker valve, just a big Henderson Mk5 pump on the outlet side. (or white bodied equivalent).
I have had Lavacs on a number of boats and found them to be charterer proof, fitted a new one to my current boat and still with original pump parts and seat seals 13 years later. They seem to be far more efficient and user friendly than any other I have had the doubtfull pleasure of sailing with, provided that users actually use the pump as the designer intended.
Your mate's problem is most likely, (as mentioned above) insufficient flushing water being pumped through and seepage back from the pump and discharge hose.
RupertW
20 Mar 2002
Greenwich
Yes but if you use a holding tank you want to flush the minimum to clear the bowl so having a perfectly working joker valve is crucial- then no bleed back at all. We get through a couple a year on each head but it’s a quick job to change.
geem
27 Apr 2006
Caribbean
It's a catch 22. Residue can stick in the joker valve. Pump through so it's clean and the valves close properly
steve yates
16 Oct 2014
Ah sorry, Its a jabsco, i was going from memory, somehing I really shouldnt be doing anymore :)
lustyd
27 Jul 2010
Little tip for the joker valve, fill the bowl with some bleach and fresh water and pump the whole bowl through on the air setting and let sit for an hour before starting. Once it's had time to clean things a bit and kill any nasties, pump some more on the air setting to get as much air in the pipe as you can to reduce backflow when removing the joker valve fitting.
It doesn't make the job pleasant, but certainly less unpleasant.
Pye_End
5 Feb 2006
N Kent Coast
More likely, if you get a syphon problem, it is on the intake. Height itself may not be enough - it may need an anti syphon valve if you get syphoning. However, if it is happening with the seacock closed then it is unlikely.
Brown water. Mmmm. Waste or algae? If waste, how much is it being pumped through after use?
Is there a flapper valve as well as a joker on the discharge?
lustyd
27 Jul 2010
I should have said on jabsco if you don’t want to ditch it a complete new pump assembly might be quicker solution.
Rather than a cheap joker valve? Why?
Yes the Jabsco has a flapper valve under the pump. If the pump is in the locked position this should be pressed down so will prevent backwash if it's working.
This video is useful for those who have not yet dismantled one, as are the other Jabsco videos on their channel.
ashtead
17 Jun 2008
Surrey and Gosport UK
Only saying as a new pump unit might be simpler for the OP to just bolt on . He can then dissemble and repair the original at leisure and have a spare unit for when the new one fails.
