jaminb
Just changed my secondary racon filter no evidence of water but got some sludge.
My approach o get a better seal would be as follows.Thanks for confirming , sounds like I am bugged !
Been using Marine 16 and the one that looks like tea. No evidence of bug last year when I inspected the bottom of the tank, have topped up twice over the season so probably used 50 litres of a 130 litre tank.
time to build a polisher and clean that tank - oh joy. The biggest issue is resealing the inspection hatch with self tappers, into a thin plastic tank, with no backing plate. It has leaked under pressure since I disturbed it last year. Any ideas ?
thanks
The two semicircles sound like a plan, but I'd use polypropylene or polyester for them, not plywood. The customary source for these exotic and highly technical materials is..........Thanks everyone. When I said inspection hatch I meant the hole for the sender unit as this is the biggest and also at the tanks deepest point and hopefully where the water and bug are. The ring of studs sounds the best solution but stretching my fabrication ability ! I was thinking two semi circle plywood backers held in place with some tiny self tapers and then the existing self tappers screw into that? Any ideas how ply reacts with diesel?
I have not added any additive in any of my last four power boats (nor in several destroyers / frigates before them). the fuel itself already costs enough, and IMHO there is no need to add any snake oil on top.
The issue is keeping the fuel dry i.e. no moisture. The bug cannot live in the fuel itself - that is it's food. It lives in the water where it meets the fuel. So keep the fuel clean and dry and you have no bug / bug residue.
I know one poster will never agree with this. But regular polishing has worked for me for the past 16 years since I bought my first power boat with a serious sized engine.
My latest boat has a light layer of crud, likely dead bug, laying below the take off point (I know this because I have observed a light build up of black strands in the base of the Racors. I have been polishing for ~ 3 months now since I installed my polishing system, and so far not much has come out. I can either spend an age opening and deep cleaning the base of the tanks, or simply keep polishing after each trip and stir up of the tanks. Each engine has large Racor 900 dual filters, so risk of a fuel blockage affecting service is quite low. This is not something that concerns me, and I am satisfied my fuel is sufficiently dry, so the issue will not get worse.
