MapisM
LOL, obviously Daka struck a nerve with his comment...And moboers learn that it isn't "just like driving a car" ?
What you're saying is something which equally affects stinkies and raggies, in my experience.
You're right, AoA and Newton do in genera contribute to sail boats. The numbers are very complex though
For Newton AoA to work you need an external force. =The props on a mobo or the tow-rope on the water ski. The work done by the foil (force x distance, where force is the drag and the compression load on the fluid below and in front of the foil) is equal to the work done by the engine (totally ignoring friction and all parasitic losses, of course)
With a sailboat there generally is no such "engine" to do any work on the foil. But there is the wind, and that is the engine. Alternatively, if you think of motion as all relative, you can think of the air as stationary and the keel as pushing the boat into the wind like a massive midships bow thruster/propeller. The maths is the same however you choose to do it. So that gives you much Newtonian lift force. Another way to visualise it is that the keel and hull make a resistance like the string of a kite, and that causes the wind to create Newtonian forces on the sail. To state the obvious, a kite flies almost entirely due to Newton, not Bernouille; it is a copycat of a waterski.
Of course on a sailboat there is Bernouille force too. The Newton/Bernouille mix depends on the point of sailing so you cannot generalise. Broad reaching is mostly Newton; closehauled has much more Bernouille. The maths is very complex and beyond me now (though not at university!)
Very crudely, iirc, on a commercial plane the bernouille/Newton mix is in the order of 25-75 in steady state no-flaps flight
Well H, we've actually been here discussing this and other even more trivial matters for years rather than just a month, if you think about it...Else we'd all have been here a bloody month.![]()
Well H, we've actually been here discussing this and other even more trivial matters for years rather than just a month, if you think about it...![]()
Yep, we definitely miss all that.No adventures, no mishaps and no exploding bogs.![]()
