Hatch Lifters
boatone
29 Jul 2001
Just a few cables from Boulters Lock
www.tmba.org.uk
Do any of you flash types out there have boats with motorised hatch lifters for the engine hatch? If so please could you see if there's a manufacturesrs name and address etc on them for me? Alternatively, if any of you know where they can be obtained I'd appreciate it.
<A target="_blank" HREF=http://www.arweb.co.uk/argallery/mobochat> My P32 and Boaters Picture Gallery</A>
Andrew_Fanner
13 Mar 2002
ked into poverty by children
I'm pretty sure Lancing do them as a variant on the hydraulic ram used on trim tabs. Certainly the instructions that came with my tab kit mention hatchlifters from the same company (TrimMaster)
Two beers please, my friend is paying.
ccscott49
7 Sep 2001
Tony! You lazy git!! Just coz' the carpet/soud deadening makes them a little heavier! Whats wrong with the wifes arms!! Hmmmm?
Forbsie
9 Mar 2002
Yeh! Much cheaper getting Margaret a subscription in a gym. She needs to be needed.
Colin, what's your password so that I can pretend to be you when I'm being lippy. You're always a safe distance away?
<A target="_blank" HREF=http://www.arweb.co.uk/argallery/forbsie>My Project Pics</A>
ccscott49
7 Sep 2001
Gordon, I didn't come down in the last shower! No way, face your own music laddie, I've enough scars from lassies already!
stefan_r
Southampton & Greece (Chios)
athito.home.services.spaces.live.com
I have one too - though it is basically a hydraulic pump (that also does the autopilot steering) with a connection to the doors.
Vetus do the pump unit, rams and all the other gubbins you will need....though may be a better idea going for a packaged all in one solution from Bennett or whoever which might be an easier install if you aren't gonna run any other gear off the hydraulics.
Cheers
Stefan
mailto: stefan@athito.com
pistonbroke
3 Jun 2002
Down South
Bennet lifters are ok, but they are an add on to your existing trim tabs and involve
Solenoid valves, pipework and oil etc.
Aquafax and ASAP both do a very nice electric ram, simple to fit with a two way switch and simple wiring.
Col
14 Oct 2001
Berks
Tony, I'm on the case as I'm after one! Might be able to source a couple of 2nd hand (but brand new) for C £30.These are the elec / Archemedis screw type. Won't know 'till W/E. PM, ring or E, if you're interested
<A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
tabmanuk
11 Sep 2002
Hatch Lifters can certainly be fitted as add-on to trim tabs or as stand-alone kit. For more information on the Bennett system, see the importers webpage - www.marinecomponents.co.uk. this also gives contact details and stockists if required. hope this helps - any questions, please get in touch!
jfm
Jersey/Antibes
Re: Hatch Lifters - Gas strut
Tony, a gas strut wd be a cheaper alternative and maybe just as good? Loads of industrial suppliers have catalogues full of them, stainless steel ones too
byron
RIP
UK -Berks
I agree, my engine room hatch(s) are fitted with plain old gas struts and work a treat. The cost of fitting a motorised unit would be horrific.
ô¿ô
<A target="_blank" HREF=http://www.freeware.mcmail.com/435.htm>http://www.freeware.mcmail.com/435.htm</A>
tcm
11 Jan 2002
Caribbean at the moment
Re: wow!
these sound fab. No, I haven't gottem. Mind you, if I had got them, they'd be wonderful. Then they'd break. So much better with ornery cheap things.
..sorry, not sure what came over me there. I would strongly recommned these BUT you also need a remote control. make sure also that the swithc to operate the electric engine hatch is very conevenient and has a very powerful lectric motor so you can WHAP! smack visitors in the face or hurl them out the windows, oops sorry dear....
boatone
29 Jul 2001
www.tmba.org.uk
Wow ... a new lease of life........
.....to an old thread !
The original activity on this thread was around a month ago but suddenly today iots awake again! In the meantime I have obtained (with the invaluable assistance of Col hereabouts) an 18" stroke electro-mechanical hatch lifter and a remote up/down switch and duly installed same as a working arrangement! Total cost around £85 plus a bit of running around meeting Col etc etc cos he found a couple in the Barge Chandlery at Bursledon and was quick enough to relate what he'd seen to what I asked the forum about !
A new actuator of same type is around £250 inc VAT .
I did seriously consider gas struts but would have needed two, one each side which v. difficult to locate on P32. Also the gas struts only start to help you once you have lifted the hatch the initial foot or so from the horizontal which is the most difficult bit !!!
<A target="_blank" HREF=http://www.boatsontheweb.com/galleryframes.html> My P32, BoatersGallery, VolpenUsersGroup</A>
Re: Hatch Lifters.........
For an old thread that would probably have been more at home on the PBO page this hatch lifters...............
................ (ohpps sorry nearly nodded off then) thread, has a strangely long life. Hi Tony I'm back.
"The Med is calling me"
ccscott49
7 Sep 2001
Re: wow!
I'm trying to work for christs sake! Can't be falling about on the floor clutching my tummy laughing! They're paying me! I can see it now, whack, straight over the side!!! If you got a really powerful one, you could do a James Bond, Aston jobbie, whoosh!! /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif
