HAT?
Simes
19 Jan 2005
IofW
When you do you secondary port "Height" calculation, simply extrapolate the differences as far as HAT for the Standard port.
If you use the "Croc's teeth" method then when you draw you graph you will probably put the Standard Ports MLWS and MHWS data on the top line, using the same scale also mark the position of HAT (at the Standard Port) on the top line also (so on the top line in ascending order you should have MLWS then MHWS then HAT).
On the bottom line you should have the differences for MLWS and MHWS (ensuring that the value for MLWS and the Diff' for MLWS are at the apex)
You now draw the line between MHWS and the difference for MHWS. Now move this line parallel to the original and along to the HAT.
Now reading off the bottom line you have the Height of HAT at your Sec' Port.
Easy Peasey
Simes
scotty123
18 Feb 2007
West London
can you get the same result?
Easy Peasey
Simes
OK, here are some figures for you, from an RYA exercise
HAT Standard Port 4.4 metres
MHWS Standard Port 4.0 metres Difference at Secondary Port + 0.7
MLWS Standard Port 0. 4 metres Difference at Secondary Port + 0.2
What is difference at HAT, giving HAT at Secondary Port?
the reason for asking, is that the answer I get, using exactly your method, is a difference at best of +0.8, giving a HAT of 5.2.
The answer given (official RYA = 5.4 metres)
Simes
19 Jan 2005
IofW
Yes I Know,
Scotty 123,
Yes I agree with you, this is one of a few questions that I am in conflict with this year.
I am firmly of the opinion that I trust my answers far more than those in the instructors book.
Is there a better way of working this out? I have now tried 3 different methods and all come out at +4.95m.
PM me for further discussion?
Simes
scotty123
18 Feb 2007
West London
Scotty 123,
Simes
"come out at +4.95m."
Is this HAT or the difference?
If MHWS at S/Port = 4.0, then sec/port mhws = 4.7m
If HAT at S/Port = 4.4, then HAT at sec/port = 4.4 + at least 0.7 = 5.1m + bit more.
My 'crocodiles teeth' method, gives me diff of + 0.77.
By calculation,
MHWS-MHWN = 3.6m, with difference range 0.7-0.2 = 0.5.
So, 3.6m range = +0.5 diff range
Therefore, 0.36 range = +0.05 diff range
HAT-MHWS range = 0.4m range = +0.05555 diff range, giving +0.7555 overall.
HAT at sec/port, must be HAT at Std/Port + diff = 4.4 + 0.7555 = 5.1555m.
dt4134
9 Apr 2007
Where is the MHWN figure?
dt4134
9 Apr 2007
Sorry, I should've maybe put in a bit of detail. You don't extrapolate from the MLWS through the MHWS to HAT to find the height, you need to use the differences at MHWN & MHWS and extrapolate to HAT.
scotty123
18 Feb 2007
West London
Airscrew
1 Feb 2015
Hamble River and Nidri - Ionian
Incase anyone in the future is asking about the HAT at Farlow, it is on page 12 of the Almanac, Tide Streams/Levels, listed with all the other HATs.
There is no calculation needed. It is given as 5.4m.
Also check/read the bridge symbol on page 9.
Dellquay13
19 Feb 2021
Boat at Milford Haven, Home in Chesterfield
What do you use to teach navigation theory to tens of thousands of people?
I used the material supplied on my YM CS/OS SB (classroom based not online) and books from publishers.
I didn’t consider using unverified sources for exam revision.
Forums are great for getting a range of answers to a general question, but can give distractingly wide views to wade through when you need a concise answer to an RYA question, and if you are asking such a question, how do you know which answer is right?
I was questioning how random it was to resurrect a 13 year old thread just incase someone had a question about an entry in a training almanac, mostly because I wish there was a sticky warning on threads long dead that have been trawled up by new members, usually asking questions of the early posters directly (not in this instance I know).
