Hurricane
Hurricane - a quick question on the integration, and SPOFs if I may.
I am all in favour of systems redundancy, so does the 'integration' mean that the current data on Sys A is automatically ported to SysB and overlaid, and then back again ? Is this a potential point of failure in Sys B, if Sys A decides to go loopy and send erroneous info ?
I'm aware of the independence of the original chart data (which can't be overwritten ?), but concerned that your current geolocation may shuttled back and forth in a terminal loop. (I know from previous posts that you religiously keep the paper ones updated, so have little fear of JW going round in ever-decreasing circles).
Can the systems be run independently using separately sourced GPS data data if the other one fails ?
TIA
I'm not sure what your concern is but I think I agree with you.
My Raymarine system functions entirely separately. My PC systems feed individually into each display as "external video feeds". The PC keyboard is a long range wireless device that works throughout the boat. The PC mouse is a similar wireless device (an air mouse that doesn’t need a flat surface to work). The PC's video is also connected to other separate monitors. The PC can read/write out to the main NMEA GPS but also has two other separate GPS feeds – one of which works entirely off the PC’s power supply. Data is shared using the common NMEA feed so waypoints/routes can be set up on the PC and transferred to the Raymarine kit as necessary.
The resultant PC system provides an excellent planning system using the large saloon TV and then a good parallel system whilst “in passage”.
Here’s a couple of photos that may help understand it.
PC display on main saloon TV - good for planning but as you can see from this pic it works at sea as well.
Here is one of the Raymarine G series displays whilst under way.
And the same display a few minutes later but, in this photo, showing the PC's feed - note how useful it is to have more than one database of charts available.
I've also set the system up so that all the video feeds go to each of the displays. This reduces the chance of one piece of kit failing and screwing up the whole system but, more importantly, it means that you can very quickly switch any of the video feeds as you need them.
This pic shows the main helm with a TV (Sky) feed - not important in this discussion but it illustrates the point.
Here are some other pics that are already on Photobucket so easy to include in this post
Docking cameras
and a mix of docking cameras and charts on a single display.
The point though is that the PC system is separate and individual feeds can be switched immediatly using a single button.
