NealB
Have you tried a really big hammer?
Thanks, Bru: I've had no problems, so far, cracking my bleeding nuts, without recourse to a special bleeding hammer.
I'll bear it in mind, if, going forward, I decide to escalate things.
Tell the engine it's headed for the scrap-heap. That'll liven it's ideas up!Have you tried a really big hammer?
Please: can we stick to bleeding fuel problems, rather than petty squabbles about how someone chooses to express themself?
Didnt mean to derail the thread Neal soz.Please: can we stick to bleeding fuel problems, rather than petty squabbles about how someone chooses to express themself?
When is not 'Bleed the system' not the right answer?
Time to run this old one again
Old Listers had an oil injection plunger on top of the manifold, I presume for lube and initial firing. We used burning paper under the air inlet to start an old Baudouin 3 cyl 'ticketypop' boat engine. A gas torch is safer and easier
Oddly, I was doing research into what a semidiesel was and found that Sabb manufactured them for fishing boats before they moved to diesels. My dad had a Halcyon 27, and the Sabb diesel was very comforting - an engine you felt would go on no matter what, at revs where you could count every power stroke! Diesels are vastly more efficient, though around 12% for a semidiesel, around 50% for a diesel.Our old Halcyon 27 had a wonderful single cylinder Sabb: it must have inherited some of its genes from that wondrous beauty!
May I ask why you chose it reply to my one single post rather than reply to the previous three posts?
I was merely pointing out that the guy moaning about the guy saying much the same three times in a row (but inmportantly not exactly the same) had not read the replies correclty, and had replied half cock as it were.
As for the bleeding idea, I have never come across this idea before, and have been servicing diesels for over 30 years now,I kind of think the diesel will just lay in the inlet trunking and not get sucked in with the incoming air as there simply is not enough air movement.
1973 I was in a boat with a Lister SR4, 36hp, air cooled, in the wheelhouse with us, and I still have the tinnitus.Our old 30 foot gaff cutter had a lovely 4 cylinder air-cooled Lister.
If I remember rightly, each cylinder had a little oil bath which you topped up just before a cold start (or was that the Sabb in the H27?).
You'd have to block of the fuel return lineI've never done it, but I've heard good results can be had bleeding a diesel engine, by pressurising the fuel tank, nothing crazy, just enough to push it along the fuel pump.
Made sense to me, what do the experts think?
