Bru
OK .... thanks for all the replies.
I'm, sort of, disappointed to say that I've been persuaded not to try it.
No, no, you go for it ... just give me a minute to sort out my camera ...........
I cme up with an idea whilst servicing the PBO project boat. It has a VP MD 2020. I took out the bung on the top of fuel filter on the engine. Got the oil sucker outer pump, wound some electrical tape on to the suction pipe so that it fitted snugly in to the bung hole and started sucking with the pump. Two mins later, full fuel filters and the engine started instantly. Much better/easier than using the stupid lift pump that isnt very good. On older engines the suction pipe could be attached to the bleeding point in the injector pump.
A polite warning.Isn't there a danger of pre-detonation (or whatever the equivalent is on a diesel)? Surely putting diesel in the air-intake means that it will burn as soon as the adiabatic heating of the air and diesel mixture reaches ignition temperature - which could be before the piston reaches TDC? And in that case, it's going to put stress on the crankshaft and con-rods. The point of the injector system is to ensure that diesel doesn't enter the cylinder until just after the piston reaches TDC.
A polite warningThe knocking at 2.17 caused by this method is something to avoid as it damages the engine.
I did that but attached to the high pressure pipe on an injector...(with a little rubber hose... Started so fast I got a fright...(we used to do this years ago with plant that had been run dry and the batteries were not very good)I cme up with an idea whilst servicing the PBO project boat. It has a VP MD 2020. I took out the bung on the top of fuel filter on the engine. Got the oil sucker outer pump, wound some electrical tape on to the suction pipe so that it fitted snugly in to the bung hole and started sucking with the pump. Two mins later, full fuel filters and the engine started instantly. Much better/easier than using the stupid lift pump that isnt very good. On older engines the suction pipe could be attached to the bleeding point in the injector pump.
Try squirting just a little extra in, be sure to post some pics of the bent conrods
An outboard motor fuel bulb works a treat.This is exactly what a very experienced engineer told me to do, and I can confirm it works a treat.![]()
Naughty!????
Anyway ....... the bloody thing still hasn't started!
Thanks to all for the warnings!
That crossed my mind too. There is a definite sequence to bleed the system. If there is any air in the fuel system between the fuel tank and the injectors it won't start. FULL STOP!Sounds like it is time for you to start a new thread telling us if you have primed it and got rid of the air in the fuel system and if you have good compression.
My old donk after a winter ashore can be a bit slow to get going however one trick is to squirt a few squirts of engine oil down the inlet port towards the inlet valves. WInd the engine over decompressed to spread it around and get rid of the excess and then start. I also oil the engine bores in this way at the start of layup.
Do NOT do this if no decompressors. You will get Paulitus.
Do NOT do this if no decompressors. You may get Paulitus.
That crossed my mind too. There is a definite sequence to bleed the system. If there is any air in the fuel system between the fuel tank and the injectors it won't start. FULL STOP!![]()
Read it again.
