dunedin
You do know that it is standard practice on all moderately sized boats and upwards (certainly on a 50 footer) to turn downwind before trying to furl a genoa in anything above a light zephyr? Also often helps to detension backstay if pulled on hard.That makes sense.
In my case I had a failure to furl in 25 -30 knots - we were heading in to wind at about 40 degrees to go in to Dover port in quite big seas. They told us to come in the east entrance and at the last second gave an urgent change as a ferry was leaving through that entrance. This meant an urgent drop of sails as we were getting very flukey high gusts off the walls of the port and at that point the 6 month old largest most expensive Harken furler would not furl , and ended with me lying on the front deck under green water with feet lodged in to the inner stay and hauling like mad until I got a bit away and then trying to tie the rest up with its own sheets. This sail weighs 50 kg and flapping around is no fun! A hank on sail , even if flapping about to get it in the bag would come down straight away with a downhaul and my custom bag incorporates two long pull straps so that if I can't get it in neatly I just need loop them round the big mess and tighten down to have it safe if not neat. Against that background safety always comes first to me and hank on is safer
We certainly turn downwind in any breeze in a 38 footer.
We also occasionally use VERY CAREFULLY the electric halyard winch to assist with starting furling. But the rule is NEVER use more than two turns on winch and NEVER use self tailer - so if anything jambing the rope slips on the winch and know to sort before proceeding.
