Hand starting
dralex
9 Jun 2004
South Devon
Just out of interest, has anybody tried handstarting their diesel engine. I had to resort to hand cranking the other day as there has been so much nice wind recently that I hadn't run the engine enough to recharge the engine starter battery!!!! which is on it's own circuit. I ask the question because the fuel filter had been fitted in a very convenient place for maintaining it, but it wouldn't allow a full turn of the handle. Perhaps I'm remiss and everybody tries handstarting in preparation for that dark night when the battery is flat, but I'd certainly suggest trying it so surprises can be avoided.
<hr width=100% size=1>Life's too short- do it now.
Calluna
21 Mar 2002
Portsmouth
Tried to hand start our VP 2002 last weekend, because the batteries were dead. Gave up in the end. Seastart bloke managed to start it first time. Having been shown the correct procedure we tried again - and still failed.
I reckon a few sessions down the gym are needed before I stand even a remote chance of hand starting the engine.
milltech
31 May 2001
Worcester
www.iTalkFM.com
I've got Gardner 5LW's and there's a cranking position at both ends of a shaft provided for the purpose, and two handles. Mind you I haven't actually tried and hope I never have to.
<hr width=100% size=1>John
http://www.on-line-marine.com
jerryat
20 Mar 2004
Nr Plymouth
Hi Dralex!
Yep! I hand-start my engine, a Bukh 20, fairly regularly, as I have a thing about relying totally on batteries and starter motors, particularly when cruising in out of the way places. These days, with the approach of gibbering old age, I cannot do it by flicking both compression levers 'on' together, so have resorted to decompressing both cylinders, turning over the engine and flicking one lever on. It almost always starts and runs on one cylinder, and all that's needed is to flick in the second lever asap, and away we go. It's damned hard work, and getting harder(!) but it is certainly possible.
I have plenty of room for this operation though, with no risk of fractured or grazed knuckles!!
You're lucky, like me, to even have the facility for hand starting, and in your place I'd be looking very carefully at a way to make it fully possible. As you say, a dark night, a flat battery .....................
Good sailing!
Talbot
23 Aug 2003
Brighton, UK
My Yanma 27hp diesel outboard has a decompression lever and a starting rope like smaller outboards, but I have never successfully started it this way, nor met anyone else who has managed.
ongolo
5 Aug 2003
You could either carry a dry battery and the acid to fill it when required or invest in a simms spring starter. I am getting one for my 80Hp 4 cyl.
regards ongolo
<hr width=100% size=1>So what......... it floats
Mirelle
N/A
30 Nov 2002
Likewise (Volvo MD2 - 37 years old!) I have to dismantle the engine box to get a fair crack at it, and it certainly helps if someone else knocks off the decompressors, one at a time.
<hr width=100% size=1>Que scais-je?
snowleopard
Oxford
likewise, however hard i crank my 3GM i can never get it over the first compression after dropping a valve lifter. the handle is useful for turning it over but b****** all use for starting.
dralex
9 Jun 2004
South Devon
My engine is a Yanmar 2GM20- as you say, it's very difficult from cold. Fortunately you can decompress both cylinders.
dralex
9 Jun 2004
South Devon
I found the trick was to decompress both cylinders, then build up enough momentum in the flywheel to overcome the first cylinder being compressed-I also cheated a bit and gave the air intake a whiff of quick start. Still very hard work.
dralex
9 Jun 2004
South Devon
You must have been watching footage of the Vendee Globe- I seem to remember this was a trick one of the French entrants used to start his generator.
Magic_Sailor
7 Dec 2002
Marchwood
Mine's a great design too. The battery fouls the starting handle - so if the batteries flat - you still can't start!
The starting handles clearly never been used and has lain in the bilge next to the battery - corroding (before I got the boat) and is now useless anyway.
Magic
<hr width=100% size=1><A target="_blank" HREF=http://practical-business.co.uk>Click for website!</A>
janie
Devon
We hand started our MD6A countless times - no problems, but it was useful to have a different person flick the decompression lever. This was usually because other things needed doing to the engine at the same time!
Now we have a new Bukh we're always ready too early, because we don't need the 5 - 10 minutes starting the engine! However, you've made me wonder whether we could hand start it, and I was glad to read extravert's comments.
Benbow
11 Jan 2004
repost of note from earlier thread on same subject:
Possibly useful trick to bear in mind.
If your battery is nearly dead and won't turn the engine over, lift the decompression lever(s) and try again. The engine may well spin nicely without compression, then drop one lever and hope that cylinder fires, if it does drop the levers for the other cylinders one-by-one in turn.
Usually requires two people and beware of hair/loose clothing.
