Hand starting
snowleopard
Oxford
tried that, still can't build enough momentum to get over the first compression when i drop one valve. the lifters are useful when the battery is low as benbow says but not for hand cranking.
KevB
4 Jul 2001
Kent/Chichester
If it's a diesel it doesn't matter how flat the battery is, you are only using it to turn the engine over. After that it's the compression of the diesel in the cylinders that makes it fire/start. You could take the battery off and still start it by hand as long as your diesel pump is mechanical..
dralex
9 Jun 2004
South Devon
Exactly, but that's not the issue. It's how to get enough welly behind the handle to overcome the initial kick of compression.
<hr width=100% size=1>Life's too short- do it now.
dralex
9 Jun 2004
South Devon
Having just watched the Return of the King, I think the ultimate solution is to keep an emergency troll in the wet locker.
BillO
8 Jul 2004
I have a Cheoy Lee Offshore 27 that only starts with the crank. It has a 1 cy MD-1. I wear a glove on the right hand, start with both hands and build up the speed. After about 10 revs I move my left hand up to the compression lever while still cranking as fast as I can. I throw the lever on the downstroke and push down thru the compression, then pull the handle away. If my timing is off it either doesn't start or kicks the handle out of my hands.
Bill Ogilvie
PIGLETSDREAM
25 May 2004
Ashtead, (Office Heathrow Airport)
HAVING A SMALL 1GM10, I used to hand start her all the time, untill this weekend, when the hand start lobby thingy broke off. Still, have 3 batteries, so just have to rely on them, or fit a new crankshaft!
<hr width=100% size=1>Must go, Matron is coming
jamesjermain
Cargreen, Cornwall
Starting an old single pot Kubota by hand was no problem.
Tried the same with current, then 15-year-old Volvo 2003 and instantly stripped the rusty lugs off the shaft. Now I ensure I always run the engine for at least half an hour each outing even when sailing on and off mooring
<hr width=100% size=1>JJ
