GPS
muchy_
3 Apr 2002
Stalham, Norfolk (boat)
I have a Garmin GPS 152 and the cable to the antenna is far to long. What I'd like to know is can it be cut and re-connected as not only do I have to make it shorter but I need to run it through a deck gland. Thanks.
sailorman
21 May 2003
Here or thertemp ashore
suggest u dont even thing about it .
buy a different deck gland that will allow the connector to pass through & leave coiled-up.
there are deck glands available that allow for multi-cables to go through.
one is an aluminium ring with a rubber dough-nut that seals the cables.
ccscott49
7 Sep 2001
no problem its coax,cut it you will need a new connector fitting though and its thin wire and a little difficult.
Johnjo
8 Sep 2002
Don't see a problem with refitting the connector !
But on my set "Furuno" the shortening of the cable is strickly "no"
So if me I would coil it and stow it, all of course IMHO.
