yoda
In an effort to move into the 21st century I have decided to try and link GPS data to a laptop so that in the future I can run AIS and a DSC radio. I already have a GPS mouse aerial which gives me a position on the laptop via either the serial mouse port or the USB port. I would like to keep the serial mouse port clear so it needs to go in via the USB port. No problem so far! Now, the GPS aerial is a bit of a pain because it needs to be routed out through the hatch with all the untidy wires that go with it. Far neater would be to use GPS data from the H/H Garmin which sits happily inside the boat and is already fixed in place. Again no problem as 2 types of data lead seem to be available, one with 2 data cables (NMEA I assume) and one with a serial port connector. So, if I get the lead with a serial port connector I should get position data into the computer. Now, bear with me here, the big question is how do I then transfer the position data to either an AIS set ( I aim to fit a class B transponder in the future) and/or a DSC VHF. What I am trying to avoid is having more than one position feed. Using the Garmin data lead to feed NMEA data to the DSC radio seems straight forward but can that feed be split or fed on again to an AIS set and then to the computer. Or do I need to feed the computer with the data and then find a way of sending it out again to the AIS and DSC? If anybody a) understands what I mean and b) can help I would be very grateful.
Yoda
Yoda
