asteven221
I have a Garmin 128 gps which is linked to Seapro Lite on a laptop and a problem has appeared and I can't figure out what is causing it. All has worked fine for ages so its a fault that's developed rather than with the installation itself. Basically the position shown on Seapro and the position on the GPS are different, but only the seconds figure. The degrees and minutes figures always match. The difference is between about 6 to as much as 20 seconds. I have tried looking at the raw NMEA data on Seapro and it confirms that Seapro is displaying exactly what seems to be getting transmitted by the Garmin 128 GPS, so I reckon Seapro is not the culprit. I have compared the position information when the boat is stationary and moving with the same results. This is a bit bizarre. Has anyone heard of this type if problem? Any advice is appreciated. Thanks.
