Roberto
Hello,
I have a Furuno 1715 radar and would like to send gps data to it, so that the cursor position on the display shows its Lat/Long data. The radar can send NMEA data towards a plotter for example, but I do not need that.
The NMEA socket on the back is an unusual round 7-pin with all 7 pins on the outside and no central pin (all 7pin connectors on the internet show 6 peripheral pins + a central one), I could not find the appropriate female connector. Furuno sells a ready made cable (plug on one side, 7 coloured wires on the opposite) but it's >100euro, definitely too much for this "nice to have" feature.
The manual shows the diagram below for the plug wiring.
While searching the internet I found a (supposedly) Furuno message saying that NMEA data input to the radar is made through the Yellow (NMEA +) and Green (NMEA -) wires, numbered respectively 3 and 4 on the circuit diagram; the wire colours are related to their ready made cable.
I would like to attempt connecting the two NMEA out wires from my GPS to only two of the pins of the plug on the back of the radar; my questions
1. Is there a way to associate the pin numbers of the circuit diagram to the physical pins, those visible in the picture ? Which is number 3 and which is number 4? I only found the standard numbering for the other type of 7 pin (6+1 central one).
2. Or, is there a way to identify which pin is connected to which wire by using a multimeter (which is where my electronics knowledge ends
), I guess +12v and GND would be easy (pins 5,6,7), but the other wires?
3. The YLW and GRN are labeled respectively "RD2-H" and "RD2-C", is it normal to connect the GPS Nmea plus and minus to these two inputs, i.e. is it normal there is no connection to the Ground pin?
4. Could I make the physical connection for example with 2 single pin female Molex connectors? Or with what other means?
5. What happens if I take the NMEA out plus and minus from the GPS and try and connect it random to two pins, do I risk burning any circuitry?
Thanks in advance
r.
Thanks in advance
r.
