Chiara’s slave
It might tend to roll a bit without the mast. Low moment of inertia in the rolling plane. But you might well be used to that with motor boats. The centreboard would improve that, personally I’d put it in. But no reason why you can’t try it out without the mast.So here’s a question.
I still have some faffing to do on the mast and sails but would quite like to test the motor and check the hull does not leak or any other issues. Once I have fitted the Rowlocks so I can also row it. Could I plop the boat in on the Deben without the mast on the boat as a test of the motor and oars. And motor say up to the Rocks If I do this would she be stable and would I need the centre board in the boat as it is out at the moment. Some one told me these need the mast up to be stable but that don’t make much sense to me ?
Re the motor mount, perfect in smooth water. You might lift the prop out if it’s bumpy, but that’s an almost universal sail boat issue with stern mounted outboards. For your proposed use I can’t see you suffering much. In any case, waves mean wind, and you’ll have sails.
