Graham_Wright
The proprietary climbers get you to the top of the mast but not in a condition to perform two handed work safely. And they are expensive.
You need a length of climbing rope which you attach to the main halyard and haul to the top, then secure the halyard with clamp and knots. Take two ascenders (climbing gear) - the top one carries the bosun's chair and is clipped on to the climbing rope. The bottom one has a short length of timber attached with stout rope to act as a push bar for the feet. No bits of rope and prussic knots, swinging all over the place and unstable.
You sashay up the climbing rope pushing the ascenders ahead alternately, advancing your weight.
At the top you deploy a lanyard round your body (I use a galley strop) and the mast to steady yourself, whilst standing upright on the bar - this is stable and safe.
Usually best to assemble all work gear in a stout bag at the foot of the mast, trail an attached line up with you, and haul it up when in position..
Descent is the opposite of the above. You can also use a figure of 8 abseiler on a separate thick rope (12-14mm) hauled up at the same time as the climbing rope; stand on the wooden bar, transfer the bosums chair to the figure of 8 using a secure carabiner, step off the bar slowly placing your weight smoothly onto the abseiler and descend gracefully.
There is a warning, of course. It is not that the halyard or climbing rope will part, or the bosums chair disintegrate. No need to have a second carrying line - it gets in the way and endangers the ascent. The danger is from inversion in the bosums seat; so progress has to be steady.
I have used this arrangement for nearly 30 years and still do. When it's your life at stake you use only the best gear and check it all every time as if you were Chris Bonnington.
PWG
There's rather a lot of nonsense in your post which most will recognise.
I have a problem with not promoting our product but, suffice to say, that, even in my eightieth year, I can make the masthead in a little over two minutes. I have worked on the masthead several times in the last couple of months and I have never had a problem with "not in a condition to perform two handed work safely".
You should not use climbing rope. It is too elastic. (It is a cost you have ignored)
Nothing wrong with ascenders, I have a right hander and a left hander. Current price is around £50 (but you ignored that also). I continue to fear for my lines though, due to the (intentionally) sharp teeth. Although advised to the contrary, I cannot believe they don't cause damage. I use one ascender attached to my separate harness and move it as I climb. (Recently, I have changed to the Port West fall arrestor which I believe is better.)
"Descent is the opposite of the above".
This is practically impossible. Even experienced climbers and cavers have described it so. It depends on unhitching the ascenders (which they prefer not to do) repeatedly and alternately on the way down.
I am sometimes asked if our kit can be used for a single handed sailor. The answer is yes as the footrests can be supported by an ascender (as you have described). The only way I have found to safely descend is to abseil as do you. But the transition is very scary. I tie a separate line to the attachment between the halyard and the static line which are hoisted together and transfer to that using an Anka (aka figure of eight but better).
Inversion in a climbing harness is much more likely than in a proper bosun's chair. Mine has shoulder straps and a chest strap. The climbing harness I bought recently (#53 of this post refers), is deadly without the top part.
Your biggest mistake lies in the last paragraph;- I have used this arrangement for nearly 30 years and still do. When it's your life at stake you use only the best gear and check it all every time as if you were Chris Bonnington.
You do not mention any safety backup. The fact you have used it for 30 years and are still around to tell the tale must be down to sheer luck.
If you can think of something which may make your ascent safer, you should do it. Bit late as an afterthought as you plummet deckwards.
