RichardDunstan
I'm trying to find out more information about linking up instruments to a laptop onboard. I've run out of sources so I thought you might be able to help.
Ideally, I'd like to have the wind, depth and compass/log send information to the computer. The GPS is already tied in which uses up the laptop's only serial port. I'm looking to get an autopilot in the somewhat distant future so I would like to be able to send information from either the compass or wind to it.
I looked this up on the internet and it appears as though I need to use a multiplexer. This combines the feed from the instruments into the single serial port on the computer. It also allows information to be sent to another instrument or, in my case, the autopilot.
I've found three companies that do these multiplexers for NMEA 0183 marine applications. They are:
CruzPro NC20 - http://www.cruzpro.com/nc20.html (US$180)
Noland Engineering N183-41 -http://www.nolandengineering.com/product.html (US$190)
ShipModul MiniPlex-41 - http://www.shipmodul.com/en/index.html (US$200)
Is there anyone out there who has had any real-world experience with any of these products and, if so, can you tell us a little about how you did it? I'm also a little concerned about current draw.
For people who haven't heard about these products, here's a little explanation about each (it's a bit technical):
The CruzPro NC20 NMEA combiner accepts up to 4 (US$180) or 8 (US$250) channels of NMEA (and/or RS232) serial data at 4800 BAUD and combines these signals onto one RS232 compatible output line at either 4800 or 9600 BAUD (selectable).
The NC20 can handle any mix of NMEA and RS232 input signals at 4800 BAUD and multiple units can be daisy-chained for more inputs than 4 or 8 channels.
Noland Engineering N183-41 - http://www.nolandengineering.com/product.html (US$190)
N183-41 Multiplexer - The N183-41 Serial Multiplexer combines up to four NMEA 0183 inputs into a single serial output for connection to a host computer or other NMEA 0183 devices. A Talker port is also provided to allow the computer to send data (waypoints, etc.) to instruments.
They have a good section on explaining NMEA 0183 (http://www.nolandengineering.com/nmeainfo.html) and an excellent section on installation which covers some typical scenarios (http://www.nolandengineering.com/tips.html)
MiniPlex-41 - The MiniPlex-41 is a four channel multiplexer, connecting up to four nautical instruments to each other and a PC. Instruments with an NMEA interface can exchange data with other instruments, such as a GPS delivering position information to an auto-pilot. An instrument that delivers data is called a talker, while an instrument that receives data is called a listener. The current NMEA specification provides the possibility to connect one talker to up to four listeners. There is no provision however, to connect more than one talker to one or more listeners. It is thus impossible to connect both a log and a GPS to an auto-pilot or PC. The MiniPlex-41 circumvents this limitation by offering four listener ports, one RS-232 port and two talker ports. Now a system can be built with up to four talkers and up to eight listeners. The PC can also act as a talker/listener, without sacrificing the number of allowed talkers. Incoming data is buffered and retransmitted as complete NMEA sentences to the connected instruments and PC. From the PC, NMEA data can also be sent to the instruments.
Rich
Rich
