Refueler
I seem to be a bit stupid here and I can't quite work out in my head how or why this is happening.
To achieve the correct angle of the furling line coming off the drum, I want it to exit on the port side of the drum. But if I furl the sail to achieve this, the UV strip on the wrong side of the sail.
Is there a way to solve this?
Thanks in advance.
OK lets see if we ca clear up ...
What side is the UV strip on your existing sail ?
If you furl with the line set as you have in photo ... which shows it coiled ANTI-clockwise - does the sail furl and have UV on outside as it should be - or on inside ?
Those two answers will give us the clues to finalise.
Hint : If the UV strip is on the port side of sail - then it needs to furl up CLOCKWISE to have UV strip on outside. (Someone may correct me - but I think if it is port side UV - then its unconventional - most I know are UV on the stbd side of sail)
Your line at present turns the drum / foil clockwise to furl - but has the line rubbing on the wire frame. Therefore if its correct rotation - you need to add a small block to port side pulpit vertical to get that line away from that frame... OR lead the line down stbd side on other side of that wire frame vertical.
