Genoa size
marsbar
13 Aug 2019
I've been given a Genoa in far better condition than my old one, the luff is one metre shorter. Would it be best to hoist it up the foiles and have it a meter off the deck or keep it close to the furler and have it a metre short at the top?
Chiara’s slave
14 Apr 2022
Western Solent
I’d go for sweeping the deck. Your sheeting position might not work if you raise it, even if it’s adjustable. Also, the sail is more efficient set up like that, and has less heeling moment. However, you may have trouble with halyard wrap. These are 2 opposing factors, you may find you simply cannot get it to work.
William_H
28 Jul 2003
West Australia
As said the foot of the sail on the deck can work as a fence to eddy wind off the foot. (so more efficient like winglets on a jet wing tip) Plus of course centre of pressure is lower, so less heeling force, so good in strong winds. But then in light winds up high catches more wind. Then as said raising the saail may make correct sheeting point easier or possible. In the end give it a try down low and up high see what you like. ol'will
Neeves
20 Nov 2011
Sydney, Australia.
If you raise it off the deck when sailing to windward then seas will pass under the sail.
+ earlier comments
Lots of compromises to consider.
Chiara's Slave has the most worrying comment - halyard wrap (assuming furling sail) - which to me would the determining factor
Jonathan
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
I agree that halyard wrap is a possibility if you attach the head directly to the swivel. Add a 1 metre strop to the head and attach that to the swivel.
Chiara’s slave
14 Apr 2022
Western Solent
You’re right, that would go a very long way to alleviating that problem.
Looking under the jib, it certainly helps visibility, especially for solo sailors. If that’s worth pursuing, maybe a compromise, get it as far up as the sheeting position allows.
MisterBaxter
9 Nov 2022
I think I'd try and put it so that the clew was in the same place as the old one, to avoid having to mess about with sheet leads too much.
