mrangry
Looking on my Genoa sheets today I noticed they were badly chaffed and need replaced. They are 18mm which seems a little heavy....or is it. Its a 44ft Beneteau Oceanis and the sheet winches are Lewmar 54s.
Mine were 12mm on a 40ft cat so I replaced them with new 12mm a few years ago and they seem right to me. Maybe the next size up for a bigger boat?
Richard
On a Jeanneau 34 with a 31m sq genny its spec is 14mm for the sheet and I would not want anything smaller.
Have you checked the benateau specs?
That's interesting. On my 35m2 genoa on a cat I'm using 10mm. It's easy for me to hold, and pull, and plenty strong enough. 14mm is beast size to me. Very heavy, especially when flying around.
The Jeanneau manual for my boat (which is a 1998 45.2) gives 14mm for the halyards and 16mm for genoa sheets. Both are a size bigger than they really need to be for strength, and in fact 14mm halyards are a bit big for the masthead sheaves, so I use 12mm Marlowbraid for the halyards, but use a soft English Braids polyester for the genoa sheets because it is nice to handle. I think Jeanneau were a bit conservative in their specifications, going for strength over lightness, something that is reflected in the rig generally.On a Jeanneau 34 with a 31m sq genny its spec is 14mm for the sheet and I would not want anything smaller.
