Tranona
Something like this will do nicely tayna.co.uk/car-batteries/exide/ek600/?gclid=EAIaIQobChMIpL2Stfjj-AIVVYBQBh24nAwbEAAYAiAAEgL0JvD_BwE
That's what I have on my gen battery?Something like this will do nicely tayna.co.uk/car-batteries/exide/ek600/?gclid=EAIaIQobChMIpL2Stfjj-AIVVYBQBh24nAwbEAAYAiAAEgL0JvD_BwE
That would be my thinking. The only anxieties I have are that I’m not 100% sure the Piccolo has a built in charging system for its starter battery. There’s an option to add a charger but I’m not sure if that’s necessary or not. I’ve tried phoning EP Barrus but the only person who’s an expert on these generators is out of office and not returning my calls. The dealer I bought it off doesn’t know. (A whole another story about him…)Separate battery close to the generator. The battery will only be tiny. It gives you a fully independent system. A small stop start AGM battery would be ideal
I had an issue with my generator in as much as the small alternator had very poor voltage regulation. It was putting out over 15v. I was concerned that it would damage the AGM battery. I disconnected the output from the alternator and now charge the battery via a Victron b2b from the domestic batteries. Guess what. The Victron b2b has failed!That would be my thinking. The only anxieties I have are that I’m not 100% sure the Piccolo has a built in charging system for its starter battery. There’s an option to add a charger but I’m not sure if that’s necessary or not. I’ve tried phoning EP Barrus but the only person who’s an expert on these generators is out of office and not returning my calls. The dealer I bought it off doesn’t know. (A whole another story about him…)
I switched from two to one several years ago. It worked well. I can parallel my house battery for backup. A backup is important I think.I’m now trying to decide whether to have a completely independent generator battery or use the engine start battery.
It was this balance of power consumption that persuaded me to fit an engine driven pump for the watermaker. A couple of hours week was enough to supply water, and top up batteries if wind and sun wasn't enough for all the other power needs.FP generators have a foul reputation and that's one of the reasons we are not getting one! I agree about reliability of systems. I've had my fair share of waiting for parts in exotic places (plus paying the 'handling charge' in cash to the customs officer to get it released once it arrives...)
We have a Superwind generator and are adding solar, so I'm trying to have all options available. The power requirements of the boat are being optimised (all LED lights, water cooled condenser for the fridge/freezer etc) but making water will still be a big draw on power reserves. (I've promised Mrs M that she can wash her hair occasionally!) We don't have (or plan to have) a towed generator.
However a well installed generator with a water separator discharging water below the waterline and the cool gasses above can be extremely quiet.`. I've also cruised with a generator that gave no problems whatsoever and it was a pleasure to have 230volts on demand at any time for all sorts of reasons (power tools etc)
Mostly good. The generator performs extremely well but we’ve had a couple of issues.A year on, how is your Piccolo John? Am thinking of getting one.
Thanks John.Mostly good. The generator performs extremely well but we’ve had a couple of issues.
One was unfortunate and perhaps avoidable and definitely not Whisperpower’s fault. The generator is installed in a locker and it’s reasonably easy to get to but we didn’t notice a problem. When we did the initial checks after the first few hours running, we noticed a small drip from the exhaust. This isn’t unusual as the exhaust hose settles onto the exhaust outlet of the engine, and it was nipped up and the leak/drip was solved. However, because the generator is buried in a locker, what we didn’t notice was that the drip had landed on the electrical connector to the electric fuel pump for the generator. The generator failed a little while later. We eventually discovered that the electrical connector that had corroded and the connection was remade and all was well again. Hardly Whisperpower‘s fault and perhaps I should’ve delved deeper as to where the salt water had landed from the drip that we had cured.
The second fault was that the generator failed completely some weeks later, and I discovered that one of the pushrods had broken. A weld had broken and part of the pushrod fell into the engine. I contacted the nearest Whisperpower dealer and new pushrods were sent from Holland out to the Caribbean. However, when the engineer investigated, he managed to retrieve the broken bit of pushrod but discovered that one of the caps on the valves had also dislodged and dropped into the engine. Metal swarf on the oil filter didn’t bode well. To their credit Whisperpower have replaced the whole generator free of charge under warranty. I haven’t seen the work yet, but I believe it’s finished and I can let you know in a few weeks time when we return to the boat. Kudos to Whisperpower for responding so well to a problem that apparently is very rare but was covered completely under their world wide warranty.
Assuming no more problems, we’re extremely happy.
The generator runs very quietly and starts from its remote control at the push of a button and provides very high quality, 230 V electricity. If you were following the earlier conversation in this thread I can confirm that I fitted a separate start battery for the generator.
It’s not completely clear in the Whisperpower literature that you also have to add a battery charger for this independent battery as the very small generators do not have a built-in alternator. Easily added, but it was another expense I hadn’t expected.
I chose the fixed speed option for our Whisperpower generator. However, this was more to do with the fact that the small sizes tend to run at maximum engine rpm all the time. I don’t see any advantage in having a larger generator on fixed speed. It’s reduced noise and fuel when it’s on low output. What’s not to like?Given a choice I would always go for a fixed speed generator
I’m no water maker expert but all the ones I’ve used have been noisy. Only used 240v ones. How noisy is it? If noisy you need high output to make it quick.All good points.
The water makers I’m looking at are either the Osmosea 12volt ones or the Zen (Osmosea N12ES 12/24V Semi automatic 25-100l/hour - Sailfish Marine - Watermakers, Marine Generators, Solar Panels and more.. or Mactra Marine Equipment - Schenker Watermaker - Zen 50)
I didn’t want to go down the 220 v water maker route as if the generator packs up you’ve got no water making ability. With 12volt you’ve still got wind generator, main engine and solar potentially topping up the batteries.
50 litres an hour is enough for two of us to shower etc surely?
