Gel coat stains
Does anyone know of a potion to remove blackberry flavoured bird sh*t from GRP ??
How do you know its blackberry flavoured ????
Try Flash mixed with elbow grease.
Geoffs
15 Jun 2001
Wantage,Oxfordshire
Sounds tasty.
I use some magic gunge called Pro Marine Hull Magic, I think there is some similar stuff called Y10. On the pot it says 'the ultimate GRP stain remover'.It gets off all stains I've had, that nothing else will touch.
I get it from my local chandler in Poole. I'm sure it must be stocked by others. Inevitably, as it's for boats, it's not cheap. £11 for 200ml pot. Goes quite a long way.
robp
And as many others have posted here, Oxalyc Acid from a chemist and mix with water and wallpaper paste (to suspend). Very cheap and is what you pay boaty prices for in boaty bottles.
Geoffs
15 Jun 2001
Wantage,Oxfordshire
Is that what it is? £11 another right rip off then! Next time I'll use your recipe, mind you, it is a nice pink colour, so need some harmless colouring as well!
byron
RIP
UK -Berks
Hmmmm! Geoff, I thought you were aboard my boat when Mike Haley showed me how good DETTOX was and that stuff is only about 85p or so a spray bottle. What amused me afterwards was when it mentioned it to my Gruppenfuhrer. She knew about it all the time and produced a bottle from under the kitchen sink. Proving maybe we should always consult our wives first on these matters.
ô¿ô
www.education-jobs.co.uk
www.alexander-advertising.co.uk
claymore
18 Jun 2001
In the far North
Cause
Possibly you need to be thinking of cause as well.
Try a .22 for the birds and a bushmans for the plant then
Flash and elbow grease but which part of this sceptre'd isle do you inhabit to still be getting blackberries - ours went long ago
