CliveG
Hi All
Let me tell you of my on going battle with Sirenia's gearbox.
Sirenia has a Beta 10 engine.
The last season I had trouble getting forward gear to engage.
I finally decided to replace the Gearbox with a new TCM40P box from Beta as this is their recommended replacement.
Around Easter We pulled the engine out of its hole and installed the new box.
We put it all back together and checked the alignment - This seemed o.k. - the flange plate on the shaft slid onto the bolts of the flexible drive fine.
When we ran the engine in gear the it was rocking around quite alarmingly.
After some head scratching I thought that it could be weak engine mounts (one did look a bit sick) and I was aware that the cutless bearing was quite worn.
I had Sirenia hauled out and proceeded to change the engine mounts and the cutless bearing.
with some adjustment we got the gear box and shaft to match up.
I took the flexible coupling out and made sure that the was no gaps between the gearbox flange and the shaft flange and the bolts slipped in easily.
We relaunched last weekend and headed down river to the summer mooring.
Once on the move there was a heck of a banging from the prop shaft area.
As I had my car at the mooring I pressed on to there.
Over this week I have been trying to work out what is wrong and thought that there could be a mis-alignment with the boat afloat rather than on her trailer.
I have just checked the alignment again and found it to be as before.
The rear of the engine is still going round in circles.
The only thing I can think of is a bent prop shaft but it was quite o.k. with the old gearbox. (once you could get it into gear!).
Most likely heading back up river next weekend to get her out again.
Here is a video of the rear of the engine running at tickover in reverse (On a mooring so could not go ahead)
http://grounds.org.uk/Sirenia/Gearbox shake.mp4
Any thoughts would be welcome.
