cueball
Morning all, I have just fitted a new force 10 oven, looking for a gas safe engineer to connect the gas pipe, any recommendations, boat is on the hard at essex marina
any domestic plumber is capable and will probably be cheaper.
ooh, that's controversial ? ?Any competent DIYer is capable and would be free.
Sadly fewer and fewer of them are willing to undergo the outrageous costs of maintaining this certificate.any domestic plumber is capable and will probably be cheaper.
It costs £137 to renew a registration for a year. Additional engineers in a business are £25.98Sadly fewer and fewer of them are willing to undergo the outrageous costs of maintaining this certificate.
Thanks for the recommendation Tried Peter, he’s booked till SeptemberPeter Bell, Mistral Yachts did mine... Coming Soon (mistralyachts.co.uk)
It’s a high pressure galvanised steel hose, not sure I have the skills to change the end fitting, I’m going to check Google and youtube to see what’s involved.Any competent DIYer is capable and would be free.
That's why I won't let anyone else touch my gas and installed it myself!its gas unless you have a manometer to test for leaks after don't do it yourself else one day you could end up with a pile of ex-boat kindling.
I'll do most things myself but wont touch gas.
just stick an old bike inner tube on it and a couple of jubilee clips, it'll be fineNo, it's sensible. How difficult is it to replace a bit of hose with a clip on each end?
That's unusual, gas installations usually use copper pipe.
Simple DIY job, you said so yourself. Don't worry if it's suitable or safe, it's only gas.
The OP initially said he'd installed a new cooker and just needed it connecting. This is, as I said, a simple DIY job; just buy an appropriate low-pressure flexible hose complete with fittings, and pop it on. I've done it myself a number of times. However, the OP now says that it's a high pressure connection, and that in addition it's galvanised steel. This is a rather different situation.
