Twister_Ken
No gas at cooker, bottle full, all taps open.
What are the odds of getting a regulator that's faulty?
Is there actually no gas at the cooker or too much that it won't light but therefore looks like no gas? I have had several GAZ cylinders that were over filled and wouldn't light at the stove until some was vented off directly from the cylinder. Never ever had this problem with Calor, even though it is the same gas and filled at the same depot.
Did you leave the taps open long enough to get gas all the way through after a long time unused? I'm sure you did but got to ask! Otherwise is there a small air hole at the regulator that maybe is blocked with a bit of corrosion? Is it a simple cylinder mounted regulator or a wall mounted separate one? I did have similar problems once with a changeover type one running two cylinders and the blocked airhole was one cause.
I have similar problem. (First time I've had gas onboard... never been a fan, friends boat blew up on the Thames years ago.)
When the cylinder is 'empty', can you still hear the remnants of gas sloshing around in the bottle a little, or would it be silent when shaken?
In my case - one in 14 years and that was on the boat when we bought her.
