stubate
for gods sake, children !!
hydro carbons + air = bang at certain temperatures.
the heavier the hydrocarbon ie gearbox oil, the harder it is to ignite.
gas ignites at lower temperatures
petrol higher
paraffin higher
diesel higher
the further the piston goes up the bore in a compression ignition engine the more it compresses and the hotter it gets.
put gas into a diesel and it will crackle and pop because it is preigniting
petrol to a lesser extent
paraffin less but it will run tolerably well but no lube effect and will destroy the injectors and pump
diesel the timing is set just right
heavier oil etc etc etc
stu
petrol higher
paraffin higher
diesel higher
stu
