gjgm
Why would you use this and not the NMEA 2000 - unless I suppose you already have some legacy Network equipment installed ?
It's used for networking multiple MFD's, connecting Radar and the black box fishfinder.
It's the only way to connect digital radar and the fishfinder. It's also the only way to get full networking with multiple MFD's, NMEA connectivity would only exchange minimal data.
It's basically an ethernet network, same as your PC and same as Raymarine's "Seatalk hs". A benefit with the system on a lot of the later Garmin plotters, is that they include 3 ports, so all you need for a small network is some 99p ethernet cables.
Spot on. To add N2k imho has been a very disapointing interface to the outside world with no clear standard in sentance protocols, every manufacturer seems to have their own variation and interoperation has proven limited. Many modern installs still use old but reliable 183 to bridge to other vendors data. N2k is not what we were promised it might be. GBN has some expert data on this.
Ah, yea .. seem now to remember some drawing in their brochures with the above mentioned.
ok, so whats the way to do this then !
Garmin 5012
Garmin GPS
Garmin/Airmar nmea 2000 tri-ducer
Garmin GMI 10
non Garmin AIS 0183
If the power goes into the plotter, will that also power the other units via NMEA 2k network?
Getting a bit lost in just many of these t connectors I need ! Is it 4, plus a male and female end.
Or is there some simple way to do this without all these expensive plugs !!
Sorry Paul but you can’t do that anymore than you can use solid core electrical cable anywhere else on a boat, the reason for that needs no explanation here. the cable should be multi stranded tinned cat 5e with the correct waterproof ends as standard patch cables are solid core and have a latch securing method whereas the Garmin and other marine networks have a waterproof securing collar.
Out of interest David, what makes you say the cable must be tinned ? Because it's for marine use ? Can't swear to it without double checking, but i'm pretty sure the Garmin cables aren't tinned.
Not just tinned (for hostile environment) Paul, but unlike almost all the usual high street cat5e cable it should be multi stranded as the single core stuff will fatigue with vibration and flexing. I believe the Garmin stuff is tinned as it is NMEA certified which it could not be unless it is constructed as I describe. In fact there were some Garmin N2K cables that had to be removed from the market and stock because the carried N2K approved label and were not so they are a bit careful about it now.
Ok Paul, thanks for that.
Now, can you remould the helm for me![]()
All the N2K cables must be tinned or they cannot NMEA certified, actually any NMEA Certified Marine Electronics installer using anything but tinned cable of any type be it AC / DC / Data would be outside the parameters where (s)he could certify the installation in accordance with NMEA 0400 installation standard. I guess it is possible that the cat5, cable supplied with Garmin stuff is not NMEA certified (will check)
I've never understood why people don't use tinned cables and mostly people cite cost but I can buy it at only a 30% premium over good quality thinwall copper stranded. I pay under 30p a metre for 35/030 which is the bulk.
