Anibal
Hi everyone.
I have the above mentioned unit which is running on the latest version (41.05 I think)
All of a sudden I have lost the rudder position indicator, which used to show at the top centre of the Garmin screen. I have two Yamahas 150HP with the drive by wire set up, which does not come with a sensor for the rudder, instead it tells the Garmin where they are pointing at and Garmin translates this info in a shape of a rudder pointing towards the direction the engines are. I have managed to get the rudder position on the LC5 Yamaha display, which does not show a ruder symbol but instead it shows- and + degrees. This is better than nothing but would love to have the rudder indicator back on the Garmin display. Yamaha has said that because the LC5 shows the angle degrees for the engines, this proves that the system is working and it is a Garmin related issue. Has anyone come across this before?
Any help is greatly appreciated.
Thank you in advance,
Anibal
Anibal
