Refueler
I just wish I had more worktop ....
I made a cover for the hob…the extra work surface is greatI have measured up to create drop in wood plate to make one sink into a worktop when not in use. Its the one area that for a 38ft boat I think is lacking ... worktop space. The hob needs a cover as well ...
Duty/standbyYou boys and twin sinks, is that to match the size of your AGA you have onboard
We wouldn't be without the second sink. How do you rinse stuff with only one sink?We have two sinks, one used for drip drying washed pots.
We have a folding bucket where we stash the dishes between washing and rinsing. Sadly not enough space in our galley for a second sink.We wouldn't be without the second sink. How do you rinse stuff with only one sink?
Chuck plates etc in the sink. Set the tap on a dribble, wash then rinse as they come out and place in a drying rack after rinsing a.k.a the cook top. Not hard, or if on a full boat use the dishwasher.Not just rinsing, how do folks stop pots sliding around on a drainer board? If only day sailing, I suppose most just wait until arrival to prepare meals. OTOH, we tend to stick to normal meals/diet and the oven (even the chip pan if sea state suitable) is used underway.
What if she doesn't come sailing with you that day?if on a full boat use the dishwasher.
On passage, two sinks is essential. If the boat is leaning over, you can put pots in one sink and wash them in the other. It's very hard to do it any other way. You also easier two people as there is nowhere safe to put the washed pots. They have to be dried and stowed. Deep sinks also make a huge difference if you need to wash up when going to windward.A double sink is a great benefit, if not actually essential. It is best if the two basins are of different sizes. As well as the obvious uses for rinsing and draining, it is most valuable then for limiting hot water use. When on shore power we use the larger sink but when at a mooring or anchor with limited hot water or the need to boil a kettle, then the smaller sink comes into its own as you can get plenty of depth with little water.
Your correct. We need what suits our cruising lifestyle. We have varying requirements. For example, we have no need for a salt water tap. A large watermaker provides water almost on the bases of home living. We had a salt water tap on thr last boat where water was far more precious to usThe answer is what 'floats your boat' .... each has their own idea.
On my 25 - I make do with the single sink ... no choice !
On the 38 - I have the double sink - would be better I think if one was smaller than other - but its a single pressed stainless affair - so the two are inseparable. What I really like - is the SW to one - FW to other ....
