wallacebob
Many years ago a yard “boy” reprimanded me; never use WD40, never leave masking tape on and never use duct tape on a boat. I have broken these rules, and always regretted it. Petrol is my go-to solvent.
I had success with a sharp chisel removing boot top tape. A tip from a shipwright in the yard. Did not require much force but needs super sharp chisel.Sharp chissel
Reviews of that product include cases where its strength seems to have melted the plastic of the item beneath the adhesive.
WD40 .... the goto that so many use for so many things - but find its crap !! It really is crap !
I only have it for squirting into locks and similar that are reluctant to work ...
Penetrating oil (e.g. Plus Gas) is better for, er, penetrating seized threads/mechanisms than WD40. (At least better than standard WD40 - I see WD40 now sells a specific 'WD40 Penetrant', but don't know whether it is just the same stuff in a different can.)
For locks that aren't completely seized, graphite is better than either. Definitely makes for smooth, easier turning of locks (I've used it on padlocks and house locks and latches). You can buy specific graphite liquid lock lubricant that appears to be finely powdered graphite in suspension in a liquid (for easier application) that evaporates after you've got it in the lock, but just sanding a bit off the end of a pencil lead will do, and prevent them getting in a seized state in the first place.
I couldn't get plus gas quickly recently and tried the WD40 penetrant - seemed to work ok.Penetrating oil (e.g. Plus Gas) is better for, er, penetrating seized threads/mechanisms than WD40. (At least better than standard WD40 - I see WD40 now sells a specific 'WD40 Penetrant', but don't know whether it is just the same stuff in a different can.)
Very likely there are better dedicated solutions for most problems than duct tape, but I wouldn't ever intentionally leave harbour without a roll aboard - its uses are so numerous and its strength and adhesion generally so dependable, it is a fabulous friend."...never use duct tape on a boat."
Multisolve is excellent for getting sticky residue off. It definitely works on gaffer tape glue. It's also very useful for dressing off silicone sealants etc. I always try to have a can handy.
