xeitosaphil
Having just got around to attempting to fit my digital ammeter, which has been waiting for the end of the sailing season to arrive, and fitting the shunt to the 6mm2 - 10awg negative from the fuse panel to the battery in an attempt to monitor discharge rates of the domestic supplies, I have just discovered that this negative does not go to the domestic battery as I thought, but instead goes direct to the engine ground bolt?
I have already installed the shunt in the Negative wire between the fuse panel and the engine before I found this out.
Would this mean that the starting current could affect the ammeter by the fact that the ground is common to both domestic /starting batteries and the fuse panel? Also the starter motor has an earth strap which is fitted direct to the engine, so would this be part of a return path back to the Start battery?
At present the Negative from the domestic battery goes to a large Negative Distribution stud then to the engine ground bolt. The starting battery negative goes straight to the engine ground bolt.
If I was to take the fuse panel negative off the engine, and extend it to the domestic battery would this isolate the starting current from the Ammeter Gauge?
The digital /ammeter is only rated at 50amps, so wouldn't take starting current?
Needless to say I have not powered this up yet as I am concerned since I found this out?
