xeitosaphil
It's personal choice, the VSR wired to the output of the switches allows you to isolate it and all power from the batteries. It also allows you to fit the chargers to the battery side, allowing you leave boat with chargers on, but the VSR not working.
If you fit the VSR to the output side, put a switch in the negative wire to VSR, allows you to turn off unit with battery chargers running.
Why two mains chargers ?
Why not one and use the VSR ?
Brian
Hi Brian thanks for getting back to me, The two chargers I already fitted two years ago while ashore for twelve months. The Ctek M300 came as a two charger package, 1 - Engine Maintenance charger and 1 - House 8 stage 20A Inteligent charger which you could fit leave and forget.
Now I find I want to improve and upgrade my Charging /Battery Monitoring arrangements especially when Cruising, hence all the gauges.
I assume all the VSR cabling is rated at the max charge rate of the alternator and not the battery load capacity?
" switch in the negative wire to VSR " - Any particular type or rating?
