My first thought at looking at that rectangular void....is that you removed the engine to access the hose. I take it that it’s just an under floor lockerReplacing the seawater strainer hose to the pump, starboard engine.
Luckily I have the physique of a racing snake....
Not quite, that's access from one of the cabins, remove the beds and some of the bed platform, remove a cabinet and remove the plate that then gives access through the bulkhead into the engine room (TAMD71B's) allowing you to cripple yourself removing the pump end of the hose using a dremel to cut through the reinforcing wire.My first thought at looking at that rectangular void....is that you removed the engine to access the hose. I take it that it’s just an under floor locker![]()
The wiring looks nicely clipped. How did they manage that?Not quite, that's access from one of the cabins, remove the beds and some of the bed platform, remove a cabinet and remove the plate that then gives access through the bulkhead into the engine room (TAMD71B's) allowing you to cripple yourself removing the pump end of the hose using a dremel to cut through the reinforcing wire.
As you can see, access is err limited in the engine room.
Oooo... That's meanNot sure the jubillee clip on the water pump end is properly tight............
that is a pig of a job. Well done.
That's a lot more polte than I deserve. I knew you would have done it all correctly. Sorry couldn't resist. Great job though.Oooo... That's mean![]()
And is akshully retiring next year!Mind you this is a chap who thinks Ducatis are the Bees Knees !
…should have gone to specsavers…It's my interpretation.
