Bouba
Thanks P, all good stuff. In fact after ten minutes my pressure gauge read zero...but there was still a lot of pressure when released from the tank. That is why I didn’t trust my pressure gauge but by then I decided to add fuel to see if the leak restarts. So after five days I pumped out of the bilge a quarter of a litre of dirty watery looking fuel. Before I was getting half a litre a day of clean golden diesel.Ok, so you tested an 800 liters tank by filling 3/4 of it with air pressurized at 0.2 bar for ten minutes.
You previously said that during that timeframe you could see the gauge dropping slowly.
Just guessing a bit now, did it drop to what, 0.18 bar? If the drop would have been even less, you would have struggled to see it on the gauge, so maybe it was even more - but let's stick to 0.18, for sake of reasoning.
A bit of math (didn't do it myself - easier to use a Boyle's law online calculator!) tells us that a pressure reduction from 0.2 to 0.18 bar with a total volume of 600 litres implies a leak of exactly 10 litres of air.
Now, let's leave aside the fact that I'd be worried by a leaking tank regardless of how "big" the hole is, if nothing else because there's only one way the hole can develop over time, and it's not in the direction of getting smaller.
Fact is, the only conclusion you can draw from your test is that there's a 1 liter/minute leak.
Or more, if the pressure actually dropped to less than 0.18 bar - and I have a funny feeling that it could well have been the case.
Personally, I'm not sure I'd dismiss that as "not big".
Mind, this is all theoretical of course, and even assuming that the leak is exactly at 1/4 of the total tank height, I guess that after filling up, you never found 600 liters of fuel (i.e. 3/4 of tank) in the bilge after 10 hours - which is what would happen with a constant leak of 1 liter/minute.
But that's because the real world leak rate depends also on other considerations: first and foremost, actual fuel pressure at 1/4 tank (even if it depends on how high the tank is) is certainly much lower than 0.2 bar. Besides, I guess it's a bit easier for air to find its way out compared to fuel.
Then again, whether it takes one minute or one day for one liter of fuel to leak out of the tank, it's something that needs attention anyway!
Sorry to sound a bit scaremongering, but I had to bang my head against the wall on this matter before, and I know how misleading these tests can be.
Good luck!
Anyhow I added another ten litres today and Wednesday I will check again but I have told the wife to expect the worse
