MapisM
Not easy is actually an understatement, also because you should:
1) seal perfectly all openings (refill, overflow, pickup, return, level sensor), for obvious reasons;
2) pressurize the tank with air at the pressure it's rated for (usually, 0.20 to 0.25 bar), but NO MORE, to avoid much worse damages;
3) fill the tank before going ahead with (2), because measuring a pressure decrease in a large tank filled only with air, at such relatively low pressure, would take forever, due to compressibility of air.
