Fr J Hackett
I have to say I would have wanted it to retain pressure over several hours with no drop, any drop means there is a leak somewhere.
The tank was isolated a while ago (I found a young mechanic working on a neighbors boat and poached him)It seems like a time-consuming method of not confirming the source of the problem. It might leak because you didn't seal something perfectly (hose, vent, etc.).
It would have taken much less effort to simply removed the hoses many weeks ago. If the leak stopped then you only had to add some fuel to see if it started again. No leak at this point would mean it wasn't the tank.
At least you can compress the timeframe now as any leak will be much faster when the tank is pressurised. I would still have removed the hoses before starting. Bending, squeezing and so forth might damage them and they might still be leaking for all you know. Total isolation removes that problem completely and it should be simple to seal the open pipes (e.g. Short length of hose with clamp).
You missed posting that vital step or I managed to miss your post. It does point to the tank if you are saying that the leak continued for a while after disconnecting and then stopped at a later date. A small leak could have been the hoses and engine leaking but that would have dried up pretty quickly and only been a small volume.The tank was isolated a while ago (I found a young mechanic working on a neighbors boat and poached him)
The tank continued to leak for a little while. Because of other issues with my life, time wasn’t an issue…and this season there will be a lot of unemployed superyacht mechanics available..(I don’t wish to make light of a serious situation).
Yes…my fault, I did miss reporting that?You missed posting that vital step or I managed to miss your post. It does point to the tank if you are saying that the leak continued for a while after disconnecting and then stopped at a later date. A small leak could have been the hoses and engine leaking but that would have dried up pretty quickly and only been a small volume.
I can't understand why you'd re-connect the hoses again, that wouldn't make any sense. I assume that you left them disconnected and pictures show small hose ends screwed on and then clamped to seal. That would make sense.
I can’t remember ? three I think and I kept on for ten minutes and then repeated. I don’t trust my pressure gauge but when released a lot of pressurised air left the tankwhat psi did you go to boubadoo’s?
Yes…but…this whole thing was in danger of turning into a science projet ??You might be better off making a manometer and watching for a drop in pressure that way, far more sensitive than a poxy little pressure gauge.
I have never seen one painted blue.My passerelle was installed to Lloyds of London Navy Standard
Hey, @Bouba , head back to Discord - and don't take any one there seriously
The balsa core is so soaked it’s oozed out .
Still don’t know how it’s got there in the core .
Well from the info thus far bearing in mind the new position / tilt on the hard they usually are blocked bow high .Well higher than when afloat .Christ. Kick him in the nuts.
What is Discord?
