TNLI
Is that a section of loose insulation
No idea, but there are only 3 main ways of fitting a fuel tank. Firstly it could have brackets thru bolted or even welded if the hull is a metal one, the tank or tanks also have straps as do most plastic ones, OR all of the sides apart from the top have one or two part foam sprayed into the gap between the hull and the tank.
