julians
dont use a compressor - you only need a couple of psi - a car tyre foot pump should be fine.I have a compressor and could pressure test it myself....but I am reluctant to do it while I still have 200 plus liters in the take..it could make quite a mess
If you're only leaking half a litre a day under normal pressure, you're not going to cause a mess unless you blow the tank apart ( hence keeping the pressure v low)
a cheap low pressure guage will detect any pressure drop - something like this
0..0.6 Bar (0..9 psi) Pressure Gauge Below Plastic/Brass 63 mm Class 2.5 | Tameson.co.uk
