Phoenix of Hamble
Will it move its full travel while the pump is still attached to the engine?... or just move to take up any slack in the system?... i'm just trying to understand how I can ascertain if its freed up.Rack can be moved with fingers, do not force with tools. essential it is free to move, as if it sticks in the full on position, stop lever might not be able to shut down engine.
In addition I ask, as I had also thought about the fact that the engine will effectively be uncontrollable if its stuck, as you say, in the full position, and will presumably only be stoppable by starving the air or fuel supply, neither of which would be ideal!!!!
In answer to other observations, its a isolated oil system, not from an engine feed, so that needs checking too... and the only two bleed screws are on the front as far as I can see.... only other fixings are the oil drain, fill and level check, besides the obvious mounting bolts.
