stevd
If you do find that the rack is jammed on the injector pump, I wouldn't try and free it in situ. The linkages can be fragile and easily bend, which will cause even more headache in the long run trying to diagnose. If the rack doesn't move easily, remove the injector pump. I would hate for you to do more damage to parts of the engine which are not as easy to get at.
Another reason I say to take it out is because, if the rack does move freely,and the governor linkage moves freely with the unit out, it could be that corrosion on the ball on the rack, or corrosion on the linkage itself is stopping it from moving. They are finely engineered so any slight differences can have a large effect. This has actually happened to mine.
