179580
You will feel it when it comes on compression. Should just about stop dead.I have a hand crank so I’ll try that but you reckon should take a bit of puff to move it?
Richard,I have a hand crank so I’ll try that but you reckon should take a bit of puff to move it?
Richard,
just come down to the boat and I can turn the crank by hand so looks like I got no compression. Does this mean the end of the engine or is there some fix I can do?
Richard,
Can’t get one for the next few monthsYou need a mechanic to check it out ..........
I’m wondering if the fuel is blocked at the jet point just before it enters the cylinder. If no fuel is getting through then that would cause low compression? I can see fuel at the injection pump and there was signs of air so primed that out. Is it possible the fuel is blocked at the atomiser? So no fuel entering the chamber would result in low compression?Are you sure decompression lever is not stuck ... is closed fully ?
A small engine like this - possibly you could turn it by hand fully over 2 or 3 complete turns ... BUT at one particular spot - it should get seriously hard as you try to turn piston through top dead centre (compressed point) needing serious effort to turn.
I can put a large adjustable on the crank of my 4 cylinder Perkins and turn it through compression - very hard - but I can do it.... I usually do that after winter to make sure engine turns easy for starter ..
my 1gm10 has no glow plug to remove to fit the tester.To check the compression you don't need mechanic. You can do it yourself. Just buy Diesel Engine Compression Tester Kit (about 28GBP) and follow the instructions.
Easiest way is to check the compression trough glow plug holes- they are standard and compression tester kit comes with a number of adapters with most common sizes.
Plenty of videos on Youtube as well.
Lost compression is sure evidence of a problem but in most of the cases is not the end of life of the engine. Could be caused by stuck piston rings.
Forget about fuel. You either have something which can probably be easily fixed like a valve stuck open or a decompression lever stuck open, or something which needs more specialised knowledge.I’m wondering if the fuel is blocked at the jet point just before it enters the cylinder. If no fuel is getting through then that would cause low compression? I can see fuel at the injection pump and there was signs of air so primed that out. Is it possible the fuel is blocked at the atomiser? So no fuel entering the chamber would result in low compression?
Asking a mechanic to come out to see an old boat worth nothing is not easy unless he is a pal. I guess I got no pals who are diesel mechanics. Getting trades men in this economy to look at a wee job is hopeless. Trades people are looking for big bucks. I spoke with one marine engineer and he said nobody is booking new appointments at moment. There is a 3 - 4 month wait so guess I’m going to try and figure this out myself with help from the forum and utube!Forget about fuel. You either have something which can probably be easily fixed like a valve stuck open or a decompression lever stuck open, or something which needs more specialised knowledge.
Do you know anyone who could take a look at it as it should only take a few minutes to find the cause of the lack of compression?
Richard
I can safely say I have low compression.my 1gm10 has no glow plug to remove to fit the tester.
A free check for substantial compression is hand turning a few full rotations, if you don't have to strain at one particular point every other full turn, it's not right. A chalk mark on the fly wheel can help to confirm the resistance is always at the same point of rotation
there are plenty of sites on the net with 1gm10 manuals which have layout drawings to show where things like the decompression lever can be found.
The ES acts as a "fuel", give one or two ignitions. It will "pop" if there is decent compression, even in the complete absence of actual fuel oil.It's not "popping" on EasyStart because there's no fuel getting in.
I’m took the cylinder head off. Replacing gaskets and notice the exhaust exit hole is badly clogged up with carbon deposits. Cleaning up where the head meets the block, replacing zinc anode. I notice one of the head bolts was a bit loose. I’m groping in the dark hereHave a look at this link
Bleeding a diesel engine
It's about bleeding a 1GM10 but it might give you a clue about leaver positions.
Also google 1GM10 and look at images, you might find something relevant that you can follow the link to.
