RichardS
N/A
When you took the head off and inspected the gasket, the valves and seats, was there any obvious issue which would cause loss of compression? If not, can you see any movement in the piston as it moves up and down the cylinder or any obvious pitting or scoring in the bore?
If it all looks good, use some thin oil in the bore to see if it drains down past the rings. If the oil vanishes within a few seconds then you probably need a rebore and new pistons. You can use diesel for this test but you will need to change the oil before running the engine.
You definitely need to identify the source of the compression loss before you reassemble the engine.
Richard
Richard
