BlueSkyNick
We have a Thornycroft T80 engine which has been playing up a bit recently.
In an attempt to resolve what I thought was a problem with either dirty fuel or an air leak somewhere, I am now unable to bleed the system and hence start the engine. There is a manual primer on the fuel lift pump which is intended to bleed air through to the screw on the injector pump. However the lift pump is dry, in that it is not drawing fuel from the tank (via the water seperator).
I removed the pipe which comes from the tank and tested the pump by operating the manual primer, but it does seem to be creating any suction.
Is there anything inside it, such as a diaphragm or whatever which could go wrong over time? Maybe a replacement pump is required? Or does the pump itself need to be primed in some way? How do I create a vacuum in the supply to the lift pump? I tried sucking on it a few times to get the syphon going, but all that has done is spoil my appetite for the evening !!
All help gratefully received.
<hr width=100% size=1>Never test the depth of the water with both feet.
