Fuel Gauge
SteveA
31 Dec 2001
Cumbria. UK
I have a fuel sender unit which goes from zero resistance when tank full to about 70 ohms when empty. The trouble is the gauge always shows full as soon as I power it up. I've checked the circuit and there doesn't appear to be anything wrong there - is there a way of checking the guage in isolation? - or any other ideas what might be wrong, it's made by VDO.
<hr width=100% size=1>
robind
23 Jul 2003
sussex
connect a different negative connection from a known source that works, with a spare bit of wire and it should work.
Regards
Rob
<hr width=100% size=1><A target="_blank" HREF=http://www.rejuvanu.com>RejuVanu</A>
Stemar
12 Sep 2001
This may be a red herring, but if everything else seems to be in order, it may be worth investigating.
I don't know about boat instruments, but at least some cars have fuel and temp guages that work on a lower voltage through a regulator so the guages' calibration doesn't change with battery voltage. Feed one of these 12v and it'll show full irrespective of the true level, but possibly not for very long...
Good luck
SteveA
31 Dec 2001
Cumbria. UK
Thanks for the advice - it's the first time I've had a chance to try and sort this out in about 4 years (tanks always full otherwise). I've a feeling the 'dirty' earth might be the answer - I'll hopefully be able to have a look this week.
