Bathdave
Anyone got any figures for how many lph an Eberspacher is likely to use?
IIRC, my D2 says up to 0.6lph.
When I did the calculations a few years back, it was cheaper to run a 2KWh fan heater at my then marina's lecky rate.
If you're on shore power, a fan heater is far more efficient. It doesn't have multiple outlets though.
I usually do so too, but I plan to change to fan heating this winter. I've filled the diesel tank to exclude moisture, and I may as well keep it full.At typical marina shorepower prices, there's little difference in cost. I prefer to use my Webasto as it heats the boat more evenly.
No they are not, the major issues are fuel and poor installs.Most problems with boat heaters are due to low voltage cutout.
And I'd guess that the majority of poor installations are bodged DIY jobs. This is all the more surprising when you consider the efforts which Eberspacher in particular have made to publish their manuals freely on the internet.
I bought a cheepy ex-BT unit off eBay.... DIY install. (followed manual as far as possible)
Always starts up..... runs for hours and hours. Usually run it flat out. 6 years in, one major DIY service (it was spotless inside) all is good.
My Eber D4 has worked faultlessly since I stopped using high sulphur diesel in it.
