oldfatgit
Do you have shore power? I have used a small fan heater to heat the bottle in its locker in order to make that essential brew. Now keep a small electric kettle on board to for such emergencies.
it would keep the surrounding air from carrying away the cold produced by the gas boiling.
If you are going to use lots of propane all year round, it is quite easy to buy a POL to POL connector and refill a small bottle from a (much cheaper) big one. A refill for a 3.9kg propane is just over £15, and for the 13kg refill it's about £25; thus making a DIY refill about half-price and even less from the 47kg one.
p.s. What actually happens to the gas system in these temps?
Years ago, mountaineering in winter, we used to put the canister on top of the pan we were cooking/boiling, inside the tent. Worked a treat!
Also had frozen fuel on boat a few times, mostly when the canister was low, but sometimes during really cold temps also. I used to shake it and allow it to suck the heat out of my hands at the same time. Worked OK but hurt hands!
Fit one of these (or similar) and then you can swap between propane or butane
http://tinyurl.com/cc96g6x
Thanks for all the suggestions folks.
My dislike for gas continues. I swapped out the gaz cylinder for a propane regulator and bottle (£25 in all). I now have 6kg of propane, and it's working a treat.
However, during the swap over the gaz bottle decided it wanted to vent itself after I disconnected the regulator, so after some swearing, some strong smelling gas, and some fear of imminent combustion, I managed to remove the regulator from the pipe and refit it to the bottle to stop it venting. It's now on the pontoon as I refuse to have it on my boat.
I tested the fit of the new regulator with some soapy water, and it's fine.
I really don't like this gas business. I'm going back to Origo as soon as I can afford it.
some gaz bottles have left hand threads. If it had a valve, by chance was the valve in the open position when it was meant to be closed ?
there is a forumite who has this for sale
Haha. It that paraffin fuelled? I absolutely need an oven. I've just acquired an oven with the new boat, and I didn't realise quite how much I missed ovening things. If I go gasless, it'll be with the Origo 6000.
