ss2016
My VP D6 has a Racor 500 pre filter, My query is about daily draining. I don't, though I do look at the bowl for water or debris. To date, 180 hrs, I have found no water and minimal debris at service. Daily draining of a small quantity especially when using a 'strange' supplier does make sense to me, however there is a problem, which leads to my question.
Since the fuel level in the tank is slightly below the filter (perhaps not when it is full), if I open the drain valve at the bottom of the Racor, a dribble of fuel comes out but an equal (or possibly greater) amount of air goes in. Clearly shutting off the tank would ensure equality but it's hard to get to. Either way I have a small amount of air in the Racor. Now the book says take the top off and top it up. I am loath to do that since frequent removal risks damaging the two O-rings both of which need to be intact. Not refilling the Racor means air will build up over time with frequent sampling reducing the amount of the element 'working'.
So my question is what is normal practice? Am I missing a trick? A subsidiaries question, will the tiny amount of air in the filter get cleared through the engine or could it in fact bring it to a halt if not bled?
